K2e2vin
ref: Hybrid ITB
Anyone know if its possible/how to build a remote float; mainly the accelerator circuit? The fuel is introduced at 0psi; does it still need a float/valve(ive read that the level in the bowl affects the a/f ratio)?
Also, i got some 30mm porsche venturis. I wanted to the an annular-type booster venturi setup, but will a straight-leg booster be better? Also, is a 30mm booster venturi too big?
