apexi power fc question
trini
i have a power fc in my jdm type r ,the engine is currently turbocharged,my engine has never idled properly,for it to idle without cuttin off,i have to go into the setting in the power fc PIM VOLT and change the 1000rpm setting to 1495 which is the max it can go,i also have to change 1.0v in the same PIM volt Setting to 149%also in order for my car to idle without cutting off,if anyone is familiar with this unit could you explain to me why i have to do this,and what exactly i am doing here that makes it change the idling,thanks guys,i know this is a technical one but i really need help urgently,thanks.
