asap need answer now
Discussion in 'Engine Building' started by kreater305, Oct 25, 2002.
  1. kreater305
    kreater305 Junior Member
    I'm in the hassle of taking off the water pump right now. My problem is that i had a new water pump that was supose to be a gsr water pump. When i took off my gsr water pump it was different. One had 22 teeths and the other had 19 teeths. Which water pump as the 22 teeth? I think its gsr. Which water pump as the 19 teeths? I think its the ls. I know when you use the ls water pump you have to use the ls belt. Will it hurt the car to put a ls water pump on a gsr?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I believe that the GSR water pump has 22 teeth, the LS pump has 19 teeth. The GSR pump reaches full output after the LS so it has to be gears to spin a little slower than the LS.
  3. pissedoffsol
  4. Havok
    Havok Senior Member
    Florida
    [smartass] Wow Brian, that helped him a lot! [smartass]
    Don't ban me!!
  5. pissedoffsol
    lol- yeah that was kind of a gay post- but ls/vtec answerd the ? so i just put in my 2 cents.
    having a wrong tooth with have your timing so fucked after 3 revoloutions! haha
