automatic to manual
Discussion in 'General Tech and Maintenance' started by El Capitan, Jul 30, 2005.
  1. El Capitan
    El Capitan Junior Member
    one quick question, im lookin at a 96 hatch, and i found one for a good deal, not the color i want though i know how to paint it, and its an automatic, and i would really like a manual, so my question is should there already be somewhere to bolt up a pedal assembly and gear shift in the car or is it lotsa fab and drawings and engineering stuff? (sorry i tried searching but i guess in using the wrong search words)
    Thanks so much in advance :D
  2. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    well there are a couple of topics about this here @ hondaswap....
    Theres no fab whatsoever unless you're broke like me,...lol If im not mistaken all you need is the auto to maual tranny mount from http://www.Hasport.com
    You'll need a manual pedal assembly tingy and it should bolt right on with no problem..
  3. 92dxhatch
    92dxhatch Senior Member
    nor*cal
    not worth the effort in my opinion, try searching for the one you really want, its out there, good luck yo!
  4. confusatron
    confusatron Senior Member
    Chicago area
    Im doing the auto to manual conversion on a 93 hatch, and yeah, dude just find yourself one that's already manual, its a LOT less hassle, and chances are it will cost less if its a five speed. Find yourself a stripped down base model, like a CX i think is the lowest trim level, with a 5 speed manual. Save yourself a few hours at the junkyard and fiddling around under your dash bent over backwards at a weird angle straining your back and neck muscles bolting the clutch pedal in and screwing with teh hydraulic line install. It's not that hard, but trust me, save yourself the hassle and buy one that's already manual. It just ain't worth it.
  5. ksrcivic
    ksrcivic Senior Member
    Sacramento California
  6. confusatron
    Chicago area
    And its also gonna cost you a lot in parts. I'm learning that right now. If you're lucky you can find a lot of parts at the junkyard, if they even have a car like yours to strip, which out here there aren't many. And even at the junkyard I spent about $100 on parts. I found exactly one civic hatch, and was lucky it had most of the parts I needed. But the other parts I needed are costing me hundreds of dollars in total. It all adds up bro. Save yourself the money and hassle and just buy a 5 speed civic. I wish I had. :(
  7. brian11to1
    brian11to1 Senior Member
    its only a hassle if you let it get to you.
    its only a hassle if you have only one car.
    its only expensive if you dont search for parts. it's easy to get the parts you need from a junk yard. just simply search as best you can, resort to the internet when you need to do so to find certain parts.
    ive done a few at-mt's. they arent easy, but by no means are they hard. unless of course you arent mechanically inclined, I guess.
  8. confusatron
    Chicago area
    With all due respect, I think you're missing the point. This guy is asking us if it is worth it to buy himself a civic that isn't manual, and convert it TO manual, just so that he can do a motor swap into it.
    My advice to him is that for the money and extra work, he is better off buying a civic in the same body style he wants, that is ALREADY manual. I am saying this for these two very important reasons: 1) The manual civic if it is the base model, will likely be cheaper and also lighter weight due to lack of
    power windows and locks, and possibly even A/C on some models. and 2) the manual civic will save him the unnecessary extra expense and hassle of the extra parts and conversion steps, in addition to already getting the car for less than the automatic. He asked for advice, and you are suggesting he spend a lot more money and time on the project, to get the exact same end result. I am suggesting that he save himself the $$$ and extra hassle, just because it's the wise thing to do. Why blow cash if you don't have to to get the same car in the end? :)
  9. Estorvito
    Orlando FL
    :ditto:
  10. brian11to1
    Bah, thank you!
  11. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Brian and I have both done this swap, I have done it on a 5th gen civic, and brian did it on his 2nd gen integra. His integra sounded like a LITTLE more work but only a little bit more.
    Alot of automatic chassis sell SOOOOOO cheap. Really, unless you buy all new parts, it will not cost you a ton at all. The extra parts that you need if your swapping everything otu (including engine) would be....
    Pedal assembly (all three pedals)
    Clutch master cylinder and resvior
    Hydrolic lines
    the Hasport mount
    coutter pins
    Small sheet of metal
    Caulk (or weld it in place if you have one)
    drill bit and 2 nuts and bolts to fit
    I have done this swap and it took a little less then one weekend to finish and that was in near zero tempatures. It is not an impossible swap by any means
  12. brian11to1
    exactly, not hard at all.
  13. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i've done this as well
    note to junkyard people
    try to find a car with a pulled motor/trans
    getting your hydro lines is much easier...
  14. confusatron
    Chicago area
    You also need:
    Shifter linkage
    Shifter
    Shift boot
    The junker I found didn't have an uncut set of linkage bars, so I had to order some online. Wasn't cheap. The rest of the parts I got off the junker for around $100.
    I agree with you guys that the conversion is not insanely hard, it's just unnecessary if you can get the exact same car and skip those steps completely. I also agree in hindsight about the learning experience being pretty cool, but I guess it all depends on what you want. If you have a lot of patience, do it the hard way. If you just wanna get the damn thing done, get a 5-speed car. And I don't know what part of the country you guys live in where you can get an EG Civic for $250, but around here in Chicago, clean ones go for $2500-4000. You might find a beat up rust bucket for around $1000. You guys are very lucky if you can get em that cheap. That's amazing. I guess it just depends on where you live.
  15. confusatron
    Chicago area
    Good advice. I got lucky and the only wrecked one I could find in the area had already been stripped of its motor and tranny.
  16. brian11to1
    I did the swap with my bestfriend we did it in about a day or so. I mean, if I wouldnt have went to boot camp all would have been done in a day.
    Seriously, the hardest part is drilling a hole (if you have to - cable trans).
    Advice: Get a good clutch, if you are converting from at-mt you are performance oriented, why not start good here? If you have a cable trans, make sure to get a BRAND new clutch cable. They stretch over time and if your car is a cable trans, its more then likely already stretched. Try to get all mounts and brackets as well, make it look good while doing it.
    You may also need a Manual ECU for your car, if you are keeping the stock engine/trans, otherwise make sure the ECU is for a manual. You will get CEL if it is for an Auto.
    You could also get a Manual Gauge Cluster, to keep the "not swapped" look, the main difference. The manual cluster will not have prnd21 on it. It will just be blank where these letters/numbers are. Also, the manual cluster may have a higher RPM redline than the auto.
    Im pretty much out of things to say right now.
  17. reckedracing
    NY
    black electrical tape over the auto row works wonders, hardly noticeable unless you know its there...
  18. brian11to1
    Well ya know. I like to do things the hardway.
