axle and linkage
i was wondering what kinda of axles am i gonna need if i plan on putting a 94 acura integra gsr motor in my 93 teg... another thing was the shift linkage. which one will i need bcuz it is currently a cable clutch and i plan on going to hydrolic with the swap..
thanx `lou
The linkage is the same, just take it off the old tranny and put it on the new one, also you can use the 93 axles with the new tranny and swap, just make sure you use the 93 half-shaft from the old engine.
