AXLE help for YS-1 trans.
Discussion in 'General Tech and Maintenance' started by LS/VTecEF9, Aug 15, 2003.
  1. LS/VTecEF9
    LS/VTecEF9 Member
    I have a 91' Civic HB with a B16 in it/ I'm using a YS-1 trans. The passenger side axle does not sit all the way in and seems to almost pop out and it's LEAKing really bad. I'm using 90'-93' inetgra axles and I removed the spacer and dust sheilds from the inner hub Why is this not fitting right. What do I have to do or what axle do I have to use. The driver side with the intermediate shaft sits fine it's the other side. I need help ASAP> Thanks.
  2. ebisu8
    ebisu8 Junior Member
    Hey I have the exact same problem to the tee.
