Axle keeps slipping out of tranny
Magana559
The Warden
sorry if in wrong section.
95 integra LS with B16, LS tranny, 17's, with camber and ride hight corrected.
so my problem is that my axle keeps pops out from the tranny on the pasanger side, and when I press it back in it jiggles. dosent really seem to lock......Already bought new axles on both sides and the problem is still there. I also tryed giving the axle some love taps to see if it will slide in anymore but it dose not.
could it be my diferencial is toast? Also when im driving at about 40 mph I feel the car shake.
Im not all that great at writing this stuff up. But please I need some help, any questions please ask!
Did you install new set rings? You're supposed to every time you remove the axels. It was a b!tch to get the axels in with the new set rings. Just slammed it in. They are #10 in the picture.
thats what I thought myself, Thats the reason I bought new axles. I thought the rings wore out or the bearings were going bad so I just bought new axles on both sides. Both axles have the rings, but it still jiggles in place, there is a lot of play when I insert the shaft.
Sould I go to honda and buy a new set of retaining rings?
couldnt figure out whats wrong with the tranny so now im just getting a b16 tranny, will open up the ls to see whats wrong.
check the shafts on the axles. I got an axle that was boxed wrong the spines on the one side will only be about half way and the other one should have splines the whole way on the shaft. Look at number 7 and 8 in the pics. I had a problem with the right side axle having play in it when it was installed. I was lucky enough to catch it when i was inspecting the car before I took it for a test drive. Just something else to check
What was the problem ? I'm having the exact same issue with my DA, axle slips out over time.
My axle slipped out in reverse this fall. I put it back in, and just kept an eye on it. Never happened again.
The bonus here, the car is stock (91 teg), auto trans (Wifes car, leave me alone) and I know what I'm doing. The retaining rings were in place, and the axles were new (Less than 100 miles). I couldn't figure it out. Something in the grease ball under the boot is what I figured. I can't get them out even if I tried (Without, of course, proper removal procedure)
Axles "falling" can happen for a few different reasons. One being worn engine mounts.
