Iam doing a LS/VTEC swap into my 98 Civic Coupe and I was wondering what axles can I use. Can I use gsr or type-r axles? Or am I stuck will using ls axles?
Also, do I need to change my hubs? Any and all info would be great.
You will need to change hubs if you go with Type R because the axle nut is 36mm instead of the standard 32mm which is on your car. You can use any B series axles except for the CRV and the Type R without changing hubs.
