Axle Removal
Discussion in 'General Tech and Maintenance' started by SixtySecondAssassin, Jan 25, 2003.
  1. SixtySecondAssassin
    Austin, TX
    is there an easy way to take axles off? any tips or tricks would be highly appreciated. ive tried pulling the hell out of them but if i yank any harder im gonna pull the car off the stands.
  2. paragus
    paragus Senior Member
  3. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    wedge a screw driver in between the tranny and the shaft and pop it out
  4. SixtySecondAssassin
    Austin, TX
    thanks fellas. but the thing is its on the intermediate shaft side(drivers side) and theres no good flat surface to pry against. it kinda of dishes all the way around like so: ) ( . do you think a big ass ball joint splitter would work?
  5. tomtom
    tomtom Senior Member
    central, cali
    just hit the cv joint with a hammer
    if it still wont com out just take out the intermediate shaft with the axle
  6. SolReaver
    SolReaver Senior Member
    use a ball joint separator
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If you're trying to save your axles don't do this.
  8. SolReaver
    :werd:
    seriously- if you try to pry the axle out with a ball joint separator wedged between the tranny housing and the cv joint, and its not working, something is wrong with your axles/tranny
  9. xj0hnx
    C.C.TX.
  10. SixtySecondAssassin
    Austin, TX
    thanks guys. i got that sob. i appreciate all your help.
