B-16a1 Tb Gasket
Discussion in 'Engine Building' started by fork, Apr 1, 2003.
  1. fork
    fork Junior Member
    I've got the first gen b16 in my 91 hatch, and I can't seem to find the correct tb gasket for that motor. I went to Honda and tried the b16a2 and b16a3, but they were way different. I think this is because they have the map sensor on top of the tb instead of on the firewall like the early integras do. I'm using one from a 90-93 integra but it didn't match perfectly and I'm getting a very high and surging idle and I think this is the problem. So if any one knows which gasket would would please help me out, thanks.
  2. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    the b16a1 is a JDM motor, therefore you need a JDM TB gasket. call honda - or poke around on the internet.
  3. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    The 90 model integra one should be right. 92-92 uses the same map sensor style as the newer civic's and tegs, on the TB.
    Your surging could be from otehr reasons as well. If you have a friend at a local dealership, have them put it on the scanner. This will tell all.
    I'd put money on the IAC motor on the back of the manifold. I had 3 give me fits before I picked one up off a genuine ITR for my ITR manifold.
  4. fork
    fork Junior Member
    thanks alot for the help guys
