b series fuel injectors
g2_teg_
i'll just start a new thread. that way when someone searches for this exact subject as i did, they will come up with a buncha shit to sort through...anyway...
'will obd-2 injectors work with an obd-1 ecu and obd-1 injector clips?
i have a 1996 integra obd2 i have a obd1 ecu with the convertion harness and it worked fine ..iwant it because i plan on running low boost so need to get a exspencive hondata. but ido think the obd1 ingecter clips r diffrent than the obd2 ingecter clips
Yes, the clips are different. If I am right, you will also need to get the OBD2 injectors clips along with the injectors. Then remove your OBD1 injector and clips, wire in the OBD2 injector clips, and place everything together. Should be fine then.
