seanjuan
this summer when my mechanic pulled my D he must have lost the two spacers that when on either side of the bearings in the base of my shift lever (solo short throw with abec7's)
because there are no spacers the shifter will rattle against the linkage which is highly annoying so I pulled it apart to fix it and am wondering why there are those two cylindrical weights welded on to the end of the link?
the weight on the outside isn't a prob but their is an inside one that is right behind the base of the shifter and the shifter is hitting that so I was wondering if I could just cut it off withough any probs
if that is too confusing I'll take some pics of what I'm talking about
has anyone else run into a rattly shifter after doing a B swap?
how did you solve the prob?
