b15b7 swap z6 head
Discussion in 'HYBRID -> EG-EK / DC' started by neil4646, Dec 6, 2007.
  1. neil4646
    neil4646 New Member
    ive bought the new head and the OBD1 P28 ecu for it, but what im wondering is if there is who has got a good map for this ecu?
  2. neil4646
    neil4646 New Member
    cheers,but ive managed to pick that up by looking through numerous forums, but what im trying to find out is anybody has got a map that they have found succesful which i could burn to a chip?
  3. BrutalB83
    Rochester Hills, MI
    Do you not get what Blanco's saying to you? If the motor is just a stock 1.5 block with a Z6 head then you don't need a custom fuel map, you're not gonna see any benefits from it. Unless the motor has a decent amount of modifications then running chips or pre-setup tunes are pointless.
  4. neil4646
    neil4646 New Member
    alright sorry i didnt quite get that, i am a noob, just trying to learn. what would you consider a decient amount of modifications for it to be worthwhile?
  5. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    There's a JUN chip selling on eBay (think it's knock off) that supposedly changes vtec engagement to 5500 rpm and has a 10k rev limit.
  6. BrutalB83
    Rochester Hills, MI
    :slap:
    Chips like that are garbage. All they do is F up your motor. What good is increasing your rev limit to 10k if your stock valve train can't handle anything above it's redline?
  7. neil4646
    neil4646 New Member
    agreed, ive looked into them and all they do is send a false signal to tthe ecu so it starts puting more fuel into the engine, and yes, the engine simply isnt ment to rev to those limits, although the ecus which are over here in the UK are jdm ecus and they actually have a higher limiter, probubly because we have a much higher fuel grade over here, you cant buy anything less that 97 octane and 99 octane is widely used also.
    but yeh thanks guys youve probubly saved me a few £££s
    cheers the now.
  8. HugoX
    HugoX New Member
    San Pablo Ca
    d16b7 civic dx 95
    hey i got a honda civic dx d15b7. stock motor but has a del sol tranny. i want to tune up my car but with out swapping the motor. what you guys think? also im a noob
