B16 Block and ITR Crank
brian11to1
What are these parts in good condition worth?
Will the ITR crank work properly in a B16 block?
Thanks in advance.
B16 block is worth maybe $50 on it's own.
The ITR crank it worth a good bit more. Maybe up to about $200 to some people.
You'd have to have custom pistons or rods, or both to use the ITR crank in the B16a block.
you would also have to notch the bottom of the cylinder walls so the rods will clear
