theczechone
Setup: 92 civic hatch B16A 2nd gen running a p30 ecu
My car runs well in the morning unless i turn it off and start it back up, than it runs like crap
in the afternoon the car runs ok for a while and than runs like crap (spitting sputtering missing),
I can turn the a/c on and make it run ok for a little while longer, and than it starts running poorly again (a/c doesn't get cold since the problem showed up),
In the morning the temps are around 75 degrees F and in afternoon around 100 degrees F
Prior to the problem showing up, the screw out of the distributor rotor backed out and destroyed the cap and rotor
Parts replaced or checked
MAP sensor
O2 sensor
Spark Plugs - NGK Iridium
Plug Wires - Duralast (2nd set- just to be sure)
Distributor Cap
Distributor Rotor
Parts replaced roughly 6months ago
TPS
Ignitor
IACV
Thermostat
I noticed that the vtec wire harness was just clipped in with cheap connectors so I decided to solder it in, after i did this I have a code 41- Primary Oxygen Sensor Heater. I replaced the o2 sensor and I still have the same code.
What else could trigger this code 41?
What could be causing a this problem?
I am desprate, the hatch is my only mode of transportation to work, I would really appreciate if someone could help. Thank you for reading
MAP sensor
O2 sensor
Distributor Cap
Distributor Rotor
TPS
Ignitor
IACV
Thermostat
