H hondachris1994 Junior Member Apr 7, 2006 #1 will there b any power gains with this setup?GSR=180hp B16 head/GSR block =? anyone know?
GSRCRXsi Super Moderator VIP Apr 7, 2006 #3 also if you leave everything stock and swap the b16 head on the stock gsr block, you will lose power, not gain.
H hondachris1994 Junior Member Apr 7, 2006 #4 GSRCRXsi @ Apr 7 2006 said: Quoted post[/post]] also if you leave everything stock and swap the b16 head on the stock gsr block, you will lose power, not gain. Click to expand... the b16 head I got has stage 2 cams and some head work,and I plan on putting some JE pistons and Eagle rods on the GSR block
phunky.buddha Mad scientist Moderator VIP Apr 7, 2006 #5 Then there's no way to tell how much power you will gain...
H hondachris1994 Junior Member Apr 7, 2006 #6 Calesta @ Apr 7 2006 said: Quoted post[/post]] Then there's no way to tell how much power you will gain... Click to expand... Will this setup have alot more tq than a regular b16?
jamesA Thank you for your business. VIP Apr 7, 2006 #7 hondachris1994 @ Apr 7 2006 said: Quoted post[/post]] Calesta @ Apr 7 2006 said: Quoted post[/post]] Then there's no way to tell how much power you will gain... Click to expand... Will this setup have alot more tq than a regular b16? Click to expand... He said there's no way to tell how much power you will gain... The only way to find out is to go have it dyno'd when it's built and tuned.
