B16 in 88 Si
noob23
I am swapping a first gen B16 into my 88 CRX Si. I am using a J1 tranny. I was just wondering what midshaft I use? Also, I use a clutch for a 92 GSR, right? Any help would be greatly appreciated. Thanks
you can pretty much use any mid shaft you want, you just have to get axels to match the mid shaft. Goto http://www.raxles.com/ that guy can explain all the axle stuff you need to know, he helped me out and solved my issues regarding that. As far as the clutch the 90 integra one should work out just fine.
Originally posted by noob23@Apr 26 2004, 08:43 PM
OK thanks...I was going to go with those axles, just not sure about the midshaft.
90-93 integra
Thanks to all who replied. It helped alot. I spoke to Marty at raxles also, he cleared everything up.
