i have a b16 motor in the car. im getting a gsr short block. what will i need to change to make the car run normal when swapping out the b16 short block for the gsr??( will i need to change: map, ecu, pumps, seals, ect.) all i am doing is swapping the blocks and need info. it will be gsr block with b16 head. basically, what can i keep from my b16 when doing this?
thanks in advance
thanks in advance
