awdriscol4
Im swapping in a OBD1 b16 and a p30 ecu into my 91 EF9.
I am using the 1991 Si harness to the engine, and using a conversion harness for the the ECU, distributor and VTEC/knock sensor/o2 sensor. My question is with the injectors. Do I use the obd0 injectors and resistor box or can I use the obd1 injectors and box?
I would prefer to use the obd1 injectors, as they come with the motor, is that a possibilty? If not, where is the best place to purchase obd0 b16 injectors?
Any help would be greatly appreciated.
Thanks
Alfred
Thanks
Alfred
