B16 or LS spark plug WIRES???
Discussion in 'General Tech and Maintenance' started by HatchSpeeD, Nov 12, 2006.
  1. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Can anyone help me out here. I have some oem spark plug wires that I took off my 95 LS motor awhile ago. They say p30 on the top of each plug. I always wondered if they were B16 wires or not. I needed to get some B16 wires anyhow for my B16 head.
    When I look up the part numbers online, here is what shows.
    95 del sol vtec: 32722-P30-000
    95 Integra LS: 32722-P54-000
    98 Integra LS :32722-P75-A01
    95 Inegra GSR: 32722-P30-000
    97-00 type R: 32722-P30-000
    Point being, the LS always has a different part number (P75 / P54) where as the some of the other vtec motors have the P30. My wires say P30 on the top but i'm not sure if that means their for a b16 head. Does anyone know if all LS wires say p30 on them or know the deal? I believe when I look at my buddies LS motor awhile ago his said P30 but wanted to be sure.
  2. douglas
    douglas New Member
    not sure
  3. LateApex31
    LateApex31 New Member
    Uh, if they say P30, then they is P30's. FWIW any B series plug wire will fit any B series motor (VTEC or non).
  4. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    I only ask because I could of sworn i've seen other LS motors with spark plug wires that say P30 on top so I figured it was the P30 being B16 or whatever.
    I wonder why certain b-series have different spark plug wires. One thing i'm concerned about is I just ordered a set of oem wires from honda. I ordered under the part number 94 del sol vtec because I'm using the my del sol's obd-1 b16 distributor but the motor i'm swapping in has a 99 head. The problem or confusing thing is that the 99 SI's B16 calls for a different part number (PCT). I figured, ok I doubt they changed the casting on the heads between the 99 B16 & a 94 B16, so must have a different part number because of the distributor diffrence perhaps. Well, so then why do the obd-2 Type R use the same wires as the obd-1 B16 from a del sol?? Makes no sense. Does anyone know if there's any difference? Should I have went the 99 plug wires or stuck with what I orderd?
  5. LateApex31
    All B16 heads are the same, from like 88 to 00. The only difference with any of the plug wires is the little plastic bracket things that hold them down. I'll repeat myself: all B series plug wires fit all B series heads. VTEC, non VTEC, GSR, B16 all the same regardless of Honda's part numbers.
