blasterman87
ok, working on my swap into my 89si, few problems so far..
1- the dizzy did not have a plug on it(either plug) and wires are not the same color.. help with wiring it up please.. the dizzy is labeled td-22 i believe its a obdo and everything else is obdo.
2- the injectors that came with the engine are bigger(not sure of the size) they plugged right in but i had to modify the gromments on intake to make them fit, and they make the fuel rail sit to high, the to sensors touch. the white one with 2 prongs on the intake and the one on the fuel rail that vacume hoses plug into.
3- will the d16 crank pully fit on the b16?? because the b16 has a smaller pully that doesnt allow the alternator belt to tighten up..(its aftermarket aluminum)
this swap is driving me up the wall there was so much crap missing like integra t bracket,clutch cable bracket,dizzy,diffrent injectors,ecu,linkege,..
