b16 swap recently started throwing code 21
JuS JAi Bee
Honda Scene New Kiid
so as the title states b16 swapped eg everything has been good for about a year now... last week sometime it started throwing code 21... same say i started to get a weird white smoke (on start up and around 4500 rpms it gets heavier) from the exhaust please any help much appreciated... thanks in advanced...
check your oil make sure you have enough in there, and white smoke is not good that means coolant is burning
oil level is perfect just changed it... umm... its dark right now so i cant really tell about the tint to the smoke.... but something i did notice earlier on today... i removed the header... just to see where the smoke was coming from... and its only the number 1 cylinder.... and as substance similar to oil is leaking thru that same cylinder.... but it doesnt feel like oil... its watery like maybe unburned gas and carbon.... its so weird
