Ok, I just want to make sure I have this wiring part figured out; everything is done except plugging the wiring into the ecu.
JDM B16 into 91 Si
Si harness was used to connect to B16 plugs.
So, all you need to do is connect the pw0 ecu to the 3 Si plugs (that never left the passenger footwell), right?
Plus add the 4 wires for vtec, oil, knock and 02.
But what about the wires already in the holes the four new wires will go in (I think 2 holes are empty). Do I need to relocate the 2 old wires or just forget about them?
Any info appreciated,
JDM B16 into 91 Si
