B16A / 88CRX Vacuum lines??
Rottweilercrx
Trying to figure out the layout of vacuum lines in my 88 CRX with a B16A. If anyone can help me out and relable my pic or take a pic of their own and post it, that would be great.
attachment.php
Here you go...
You will find out that some parts on the B16 intake manifold serve no purpose on a usdm 88-91 civic, and they can be removed. You may notice a few vacuum lines going no where or are open here is a vacuum diagram
A and B use a t-fitting to make into one line and connect to F
C connect to H
D connect to intake buy connecting into the pcv valve line that comes from the top of the valve cover to the intake with a t-fitting and connect to intake.
E connect to J
I conect to G
This is what it should look like once it is connected
Here's the direct link if you need it... 88-91 b16a swap
