B16RacerN2NR Working Hard VIP Sep 23, 2005 #2 Originally posted by C-Bye@Sep 22 2005, 11:09 PM WHat hoses to buy, Radiator and heater core? [post=559011]Quoted post[/post] Click to expand... the DX heater core hose should fit if i remember correctly, if not, just buy like 2 ft of 5/8 heater hose, cut to fit and use hose clamps. radiator hoses for a 90-93 integra
phyregod !!YTINASNI Sep 23, 2005 #3 Originally posted by B16RacerN2NR+Sep 23 2005, 02:55 PM--> B16RacerN2NR @ Sep 23 2005 said: C-Bye Click to expand... B16RacerN2NR @ Sep 23 2005 said: @Sep 22 2005, 11:09 PM WHat hoses to buy, Radiator and heater core? [post=559011]Quoted post[/post] Click to expand... the DX heater core hose should fit if i remember correctly, if not, just buy like 2 ft of 5/8 heater hose, cut to fit and use hose clamps. radiator hoses for a 90-93 integra [post=559432]Quoted post[/post] Click to expand... except you would use 90-93 teggy upper and CRX lower. * and the teggy upper rad hose needs to be trimmed to fit your application.
C C-Bye Member Sep 23, 2005 #4 So I use a 90-93 teg hose for upper and 90crx lower? opinions? I will just get 5/8 hose for core, thanx?
V VTECPOWER Senior Member Sep 24, 2005 #5 Just look HERE for most anything you could need for your swap, should be helpful.
B16RacerN2NR Working Hard VIP Sep 24, 2005 #6 Originally posted by phyregod+Sep 23 2005, 02:59 PM--> phyregod @ Sep 23 2005 said: Originally posted by B16RacerN2NR@Sep 23 2005, 02:55 PM C-Bye Click to expand... Click to expand... phyregod @ Sep 23 2005 said: @Sep 22 2005, 11:09 PM WHat hoses to buy, Radiator and heater core? [post=559011]Quoted post[/post] Click to expand... the DX heater core hose should fit if i remember correctly, if not, just buy like 2 ft of 5/8 heater hose, cut to fit and use hose clamps. radiator hoses for a 90-93 integra [post=559432]Quoted post[/post] Click to expand... except you would use 90-93 teggy upper and CRX lower. * and the teggy upper rad hose needs to be trimmed to fit your application. [post=559433]Quoted post[/post] Click to expand... no, you can't use the CRX lower because it's not wide enough to fit over the b series thermostat housing.
