B16a Bogging Like A Mutha!
Discussion in 'Engine Building' started by mattcalica, Jan 24, 2003.
  1. mattcalica
    mattcalica Senior Member
    k, my b16a is still acting all crazy. i got everything hooked up and the timing is good. what the hell could it be? when i put the b16 ecu in, the car just revs up and up. starts at 3 grand then revs up to 5 for some reason. with the LS ECU the car just bogs...someone help me!!!!!!
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    vacuum lines? are you throwing any codes on either ecu?
  3. mattcalica
    nope, its throwing no codes and the vacuum lines are all good...
  4. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    I've had dumb problems with the distribtor and from bad grounds that have made the car bog, shut off, tach jump around, car just do tons of weird stuff,
    so check all your grounds and try a new distribtor if you have another one laying around if not then clean the rotor/cap
    when you have bad grounds anything can happen my car would not turn over and I use to have my cooling fan turn on when I turned the key to on but once I moved the ground so it had good contact it would start up and stop turning the fan on =) as with TONS of other dumb things
    damn gounds I've had problem after problem with them till I replaced my wires and added a few more going from the battery to the distribtor
    Jeff
