B16a In 92-95 Civic
Discussion in 'HYBRID -> EG-EK / DC' started by adiboy, Jan 15, 2003.
  1. adiboy
    adiboy Junior Member
    I bought this car for like 400$ so it was really cheap.(Im from Hungary).
    only problem is that it has 1.3 liter engine, which is a piece of shit.i want to put in it a b16a.if i swap it can i still use the old gearbox?, or i have to get a gearbox , & diff. for the b16a?
    thanks for the help.
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    if you get a b16a you are going to need a new tranny, also you might want to look into a b16a sirII, because if you get the b16a you are going to need to change the distributor and (not sure about this one someone corrrect me if i am wrong) injectors to the OBD1 versions. and the b16a has a cable tranny and your car has a hydro tranny, so the SirII will probably be your best bet. You are also going to need motor mounts, shift linkage, some wiring done to get that car running VTEC, I am not sure what the euro 1.3L motors have.
    Good Luck man...
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I know a foriegn exchange student from Hungary,and we were talking about this very subject.He said that the VTi's could be found over there also and that is what you need.You have the vtec wiring in your harness you just need to tap into it or run a seperate set to the ecu.But ya Maaseyracer's right you need the tranny,also the mounts,ecu,axles,and the shiftlinkage.But you should be able to find a scrapyard with one somewhere near you and then hopefully you will be graced with everything you need.
  4. adiboy
    thanks a lot for your help.it sound pretty difficult.so i will ask that wich engine goes "bolt on" into my 92-95 civic?
    thx
  5. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
  6. adiboy
    whats the difference between obd1 and obd2?
  7. prawjEKt Cx
    upstate NY
    about 2000 cel lights
  8. adiboy
    thanks a lot for your help , but it seems like i dont know what is an OBD.if you could explain it to me , i would be most generous.
  9. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    there is an article in the article section that explains OBD --> on board diagnostics.
  10. knowledge
    knowledge Senior Member
    Beale AFB, CA
  11. danny74
    danny74 Junior Member
    :rolleyes: i have a 87 acura inter. i need information in how to build a powerflow. no one has a powerflow for my car. I also here that it's the same motor as a zc from japan.
  12. xj0hnx
    C.C.TX.
    If you really want an answer start your own thread.
