B16a In My Crx?
Discussion in 'HYBRID -> EG-EK / DC' started by PiMpCRX05, Feb 28, 2003.
  1. PiMpCRX05
    PiMpCRX05 Junior Member
    yeah im planning on buying a b16a1 motor but the only problem is i need money..hehe..no on a serious note.. what would i need other than the motor for the b16a1..it's going to be going in a 89 crx si..what would i need other than the distributor, tranny, intake manifold, ecu,wiring harness, alternator, power steering pumps and mounts? thanx
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    http://www.hasport.com/Products/Mount%20Ki...ount%20EFB1.htm
    http://www.hasport.com/Tech/Installs/EFB1.htm
    http://www.hasport.com/News/Articles/Haspo...ort%20Axles.htm
    You will need mounts, shift linkage, axels, and radiator hoses. You will find all that info and more in the previos links.
    and depending on which crx you have i.e. DX or STD, you will need to do an MPFI swap. if that is the case here are some references for you.
    http://www.hasport.com/Tech/Wring/Conversi...91%20DX-SiR.htm
    http://hybrid2.honda-perf.org/tech/4gdxtozc.html
    http://crxpower.net/phpBB2/viewtopic.php?t...0cfa9f40186ba3e
  3. heterosapian
    heterosapian Senior Member
    exit 152, I-95
    check out the first link in my sig, the second is hasport which maasey posted above. That first link will tell you EVERYTHING you need.
