B16a no spark
90b16acivic
hello,
i have put a b16a into my 1990 civic si, i have a OBD0 PR3 ecu , the engine cranks but there is no spark there is power up to the distributor and i have checked the coil its good changed the cap, rotor,wires, plugs and still have nothing. but when i got the engine the disrtibutor cap was broken so could the moister have toasted the distributor or could there be other things i am over looking?
thanks
Check the ECU fuse in the engine bay.. if the fuse is good then try a different ecu..
Make sure that the coil is good.. replacing a different distributor doesn't mean anything if the coil in also bad.. I could only think of bad coil, ecu fuse busted, bad ecu, fuxked up wire connections somewhere..
