b16a swap into a 90 integra
Discussion in 'HYBRID -> ED-EF / DA' started by mikebaum, Mar 21, 2004.
  1. mikebaum
    mikebaum Junior Member
    alright the motor is in with all stock mounts the 90 integra came with a b18 in it. alxes we used a b16 half shaft and axle but on the passenger we had to use the stock b18 axle because the b16 axle was to long. So my question is what shifter linkage do you use for this swap because stock does not work. 1 and second gear are in the middle where 3rd and 4th are
    and if you think about it the motor sits more over to the passenger side that is why the longer b16a axle would work and you had to use the b18 which is shorter
    i am stuck is there a shifter linkage that will work?
    thanks in advance
  2. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    wit the tranny it happened to my car...the rod going into the tranny(shift linkage gets connected to it with the bitch pin) got bent when whoever had the tranny b4 me took it out, and it would only go into 3rd and 5th. the shift linkage from the stock integra works.
    also all of the stock integra's stuff works- u can use the stock axles, and intermediate shaft.
