B16a TPS Problem
Jdubspeeds
I dont think my TPS sensor is working correctly on my b16a. I put a volt meter on it. When my throttle is closed, I get a reading of 4.5 When my throttle is wide open I get a signal of .38 This is backwards from what STR says my TPS should be. They say it should be .38 closed and 4.5 wide open. I tested the TPS on another dx and it was .68 closed and 4.5 wide open. Am I missing something here. I checked the wire in the middle of the TPS plug and it goes into C7 on my PR3 ECU. ????? ME STUPID :worthy: :worthy: :blink: :blink:
don't know if this helps but oh well...
‘A’ connector
N/C
A15
Yel/Blk
+12V
Switched IGP1
A13
Yel/Blk
+12V
Switched IGP1
A11
Blu/Yel
Air control value
EACV (IAC) GAP
A7
Yel
Injector
INJ4
A5
Lt Blu
Injector
INJ3
A3
Red
Injector
INJ2
A1
Brown
Injector
INJ1
A18
Blk/Red
GND
LG1
A16
Bro/Blk
GND
LG1
A14
Grn/Blk
Fuel pump
FLR
A12
Grn/Blk
Fuel pump
FLR A10
Green
Purge valve
PCS
A8
Green
VTEC Spool
VTS N/C
A4
Black
GND
PG1
A2
Black
GND
PG1
‘B’ connector
B19
White
Knock Sensor
B17
White
Ignitor
ICM
B15
White
Ignitor
ICM
B13
Blu/Wht
+12V at start
STS
B11
Black
Rear
Demister N/C N/C
B5
Blu/Blk
VTEC pressure
VTP
B3
Yellow
A/C Clutch
ACC
B1
Wht/Grn
+12V always
VBU
B20
Brown
Adjust timing
N/C
B16
Yel/Red
Speed sensor
VSS
B14
Blue
Alternator
ALTC
B12
White
Dist
Crank-
B10
White
Dist
Crank+
B8
Blue/Red
A/C switch
ACS
B6
Grn/Orge
Check light
MIL
‘C’ connector
C15
Yel/Red
MAP+
VCC1
C13
Yel/Whte
TPS+
VCC2
C11
White
MAP
C9
Red/Wht
P/S
Pressure?
C7
Red/Blue
TPS
C5
Red/Yel
Air Temp
C3
Orange/Blue
Dist TDC+
C1
Blue/Grn
Dist CYL+
C16
White
O2 #1
C14
Grn/Wht
MAP-
SG1
C12
Grn/Wht
Sensor
GND SG2
C10
Grn/Wht
Brake Lt
C8
Red/Blue
O2 #2
C6
Red/Wht
Water T
C4
Wht/Blu
Dist TDC-
C2
Blu/Yel
Dist CYL-
but then again I'm having these stupid problems with my buddy's PW0 so...
you need to switch the two outide wires on the tps plug because the b16a works backwards from the dx engine
Thanks. Figured it out. Still my cars running like crap. Soo... its in the Speedshop now hopefully they will figure out whats up soon. :)
