B16a1 questions
Discussion in 'HYBRID -> EG-EK / DC' started by KornyCivic, Jan 18, 2005.
  1. KornyCivic
    KornyCivic Junior Member
    I know i know, it's not a "recomended" swap...
    But here is my question any way :) A friend of mine is planning on buying a b16a1 (SIR) swap to put in his 92 civic. he wants to use the cable tranny, but we're wondering what stock honda motor mounts can be found/scrounged ect to get this thing mounted.
    Any help would be appreciated. Thanks! Ben
  2. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    yeah i have the mount and bracket you are going to need to do it let me know pm me
  3. qtmac_mien
    qtmac_mien Senior Member
    if your friends car is hydro and he is using the cable tranny then he will prob need the cable to hydro conversion. i got my conversion from JDMSHIT.COM. the instructions they gave me was hella shitty and had to figure it out on my own but i did. if u need help on that i got some picures of the conversion.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    We have a nice picture in our reference section that will tell you what mounts to use. I don't know what mount you'll need for the cable transmission, but all the rest should work.
  5. qtmac_mien
    if your friend is using a cable tranny on a hydro car then you would prob need a cable tranny mount instead of a hydro..
  6. ej11
    ej11 Member
    SO CAL!!!
    i had to chage every thing on my b16a1 so it would work in my 95 ex coupe...
    dizzy.(0bd1)
    injectors,f/r,f/p/r.(obd1)
    02.(obd1)
    gsr front left mount.
    and hasport cable to hydro conv. (kit) with first gen tranny...
    rear cable tranny mount.
    hope this helps... :D
