I know this question has been asked before, do a search. I can't remember what the answer is.
^^ You can't just check the tranny #, it might not have come with the LSD stock...I know mine didn't. A lot of companies like Hmotors put in aftermarket LSD's when you order an LDS tranny.
the only real way is to pull out and axle and see if you can see through the diff without seeing that bar going through. Don't know if that works with after-market lsd tho.
put the car on a jack with both front wheels in the air.
spin by hand the left wheel forwards.
if the left wheel spins backwards, its got a diff.
if it doesn't spin at all, or spins the same direction, its open diff
