B16a2 Axles
Discussion in 'HYBRID -> EG-EK / DC' started by simonc, Feb 24, 2003.
  1. simonc
    simonc Member
    Hi all,
    Just transplanted a B16a2 from a 99 Civic Si into our 1993 EG hatch. Does anyone know what axles we should use with this motor?? Thanks
  2. civicSiR1
    civicSiR1 Senior Member
    use the donor axles....
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    If your swap did not come with axles, get integras axles.
  4. bossman032
    bossman032 Senior Member
    while we are on the topic of axels!!
    what AXLES ARE THOSE FROM IN THE PICTURE?
    :unsure:
  5. ekPhred
    ekPhred Senior Member
    yea, if you can, try to get axles coming off of the same engine, if not, go with what sol said and get integ axles.
    good luck!
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Almost positive the green bands are from a LS.
  7. bossman032
    thanks 92b16vx!!
    Looks like you are back!!! :worthy:
    This will THE AXELS work for my 91 DX doing a SIR II SWAP WITH CABLE TRANNY AND OBD1 ECU..
    I know the requirements for the SWAP!!!
    Just need a conformation that those axels will work with my DX 4th GEN doing a SIR II SWAP?
  8. simonc
    simonc Member
    Thanks Guys!
    Because the engine is from an EK civic, will the axles fit our EG shape??
  9. xj0hnx
    C.C.TX.
    I want to say for the 4th gens you want to use earlier teg axles pre 94.So if those are from a earlier teg you should be good.
  10. xj0hnx
    C.C.TX.
    You should be good.
  11. simonc
    simonc Member
    Should the axle be completely straight from the gearbox to the wheel, or can it be slightly bent?
  12. simonc
    simonc Member
    Just to clarify a point regarding Integra axles, can we use the axles from any model Integra, including Type R? What engines came in the 94+ Integras?
  13. pootSIracer
    pootSIracer Member
    Scotia,NY
    yup 99-00si axels I just did the same swap or 94 and up gsr anymore quetion feel free to ask +
  14. simonc
    simonc Member
    Thanks Poot. I assume you should use the halfshaft from the 99Si as well?
    Do you know if axles from a JDM SiR EG civic will fit??
