Heya,
I'm trying to get the idle problem to go away but no luck so far.. I have a b16a2 '99 in my 97 civic cx. (with cx wiring)
I have the boomslang obd2a--->obd1 with a p28 and skunk2 program installed.
Heres the problem : When I start the car , it goes up to 500-600 rpm and dies. Only way to start it when cold like (1-2 degrees celsius cold) is hold the gas until it warms up.
I checked my tps voltage and IAC. The tps voltage doesn't seem right, I pulled the switch out and played with it with maximum setting and minimum setting. minimum is 2.90volts and 4.80 max volts... far from the .45 volts I am supposed to see at closed throttle.
Anyone have an idea what it could be ?
