B16A2 engine into a 1997 EK9
Discussion in 'Civic and del Sol - EG and EK' started by yellowevo2005, Dec 18, 2008.
  1. yellowevo2005
    yellowevo2005 New Member
    north carolina
    OK I have the engine, tranny,wirng harness, all motor mounts,shift linkage,ECU
    the engine was on a 2000 honda civic Si
    what else do I need? I'm trying to do it in the next 2 weeks so I need to make sure I have everything on hands :confused:
  2. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    You need to throw it in a wire the vtec up, get axles, intermidiate shaft.....Where at in NC are you?
  3. yellowevo2005
    north carolina
    ohh I forgot I do have the axles too and midle axle holly springs NC
  4. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Then put it in....youll need some extra wiring for vtec to work but thats it. If its a EX just put it in, swap the ECU and drive.
  5. yellowevo2005
    north carolina
    well I did swap the engine before I had a D16y7 now it has a D16Y8 with a P28 but now I want to throw the B16A2
    question is the wiring from my D16Y8 and the Si ECUdon't match .
  6. yellowevo2005
    north carolina
    I have a P28 ECU that has been chipped but I would need a tune for it and don't want to have the same headacke that I had before when I chipped it for the D16 build engine that it has right now.
    I went thru 2 tuners neither one did a good job that's my concern
    i want to make it to pass inspection so it can bee OBDII :confused:
  7. yellowevo2005
    north carolina
    swap almost done
    :confused:OK have the engine installed and ready to get it running as soon as I get my OBD2A to OBD2B jumper harness from rywire since I'm not confortable with tunners around where I live since i got screwed already.
    as well Im running the engine bone stock for now.
    my questions is where can I find the second O2 sensor the one that goes after the cat I have a few O2 sensors sitting aorund but can't find the connector any help will be aprecciated
