speedehatch
All i need is a list of all the mounts/ brackets i need to put a USDM 99-00 Si motor into my 98 civic hatchback DX. If you could provide the part numbers that would be awsome but i just need a list of what i need.
Also with wiring is this correct and will it work: wiring my DX for vtec and use a OBD2a - OBD2b conversion harness connected to a 99 Si ecu.
