B16a2 Swap Into 93 Civic Ex
allmotord16rex
My friend is installing a B16A2 into his 93 Civic EX. We need to know which mounts to use in which mounting locations. He has all of the SIR2 mounts that came with the B16 and he has a tranny and rear mount from a 94 up Integra. Will these mounts get the job done, or does he need something else? Does he need a different tranny bracket? Any help is appreciated.
if you have a jdm b16a, it has the right bracket. i used the mounts off a vtec del sol, but the integra rear should be the same. dont forget to get a shift linkage
Ok, thanks. We have a SIR2 motor so it has the JDM bracket. Now, which mounts should we use for the tranny and driver side. We have in our posession the tranny and driver side mount from the SIR2 and the tranny and drivers side mount from the 94 up integra. Which ones will work? Thanks! :worthy:
