B17 Gsr Header On B18a
Discussion in 'General Tech and Maintenance' started by saturn_boy96, Mar 12, 2003.
  1. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    Got one and was wondering if i can use it with my swap? will a b16 header fit on a b18 block.
  2. saturn_boy96
    Sheridan, WY
    comn guys someone has to know. Bump.
  3. rextec
    rextec Member
    it should have the same bolt pattern as the b18. just match it up to the exaust manifold gasket for the b18. The only other problem you might run into is that the b18 has a taller deck height for the increased stroke so the header might rub on the bottom of the oil pan.
  4. saturn_boy96
    Sheridan, WY
    thats what someone else already said.
