B17A GSR in a CX hatch?
Discussion in 'HYBRID -> EG-EK / DC' started by Phou, Oct 4, 2006.
  1. Phou
    Phou Junior Member
    Yakima, WA
    what all needs to be wired when swapping the B17a GSR in a cx hatch, using the B17a ECU, would anybody have any links to any wiring diagram regarding this particular swap?
  2. boostedek9
    boostedek9 Junior Member
    depends what year hatch its going to
  3. Phou
    Phou Junior Member
    Yakima, WA
    92...but isnt it the 93's and up are the ones that are a lot easier?
  4. ef8
    ef8 Junior Member
    I know you will need to wire VTEC but im not sure if anything else
  5. hondapartshero.com
    hondapartshero.com New Member
    I am assuming your CX hatch is an EG (92-95). The wirings pretty straight forward. You'll need to wire for VTEC solenoid, VTEC pressure switch, knock sensor and convert to a 4 wire oxygen sensor. If you need any help let me know
