B18 Crank into a B16???
Discussion in 'Engine Building' started by Slimtadder, Dec 22, 2002.
  1. Slimtadder
    Slimtadder Senior Member
    Lake Havasu City, AZ.
    Does anyone know or have done a B18 crank into a B16? Would I use the B18 rods to?
    Thanks
  2. Slimtadder
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    ummm, I wouldnt reccommend it unless you want to see your pistons come through the valve cover. The physical length of the b16 block cannot handle that kind of stroke.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I thought the b16 and b18 were the same just different r/s ratio.
  5. pissedoffsol
    kinda not really sorta....
    if that makes any sense.
    if you have a b16 and want more displacement, consider a storker kit from crower
  6. kyleirwin
    kyleirwin Retired OG
    Vegas
    or you could bore and/or sleeve it.
  7. Slimtadder
    Wouldn't a stroker kit from crower be something like a B18 crank? What about that eagle kit I see all the time on Ebay? It's like a grand less than crower? Also, if I did bore/sleeve it what company makes sleeves and how far can I bore a B16?
    Thanks
  8. Slimtadder
  9. cws13
    cws13 Senior Member
    Athens,GA
    or you could just get a LS block for like 300 bucks and get more torque and reliability vs. a 700 dollar crank, 1000 dollar sleeve kit, 1500 for custom bore pistons and rods, ect. There is a reason people hardly ever do this.
