FNG Clint291
so here i am again with another problem coming from my b18a1 swapped si....driving it the other day and it starts too lurch and cut out like its out of gas but i just filled it up, so what else could it be? after said problem started i tried to rev it to pass a car and the motor coughed and gave me a heated oxygen sensor code and a map code, but the map sensor is brand new and all the vacuum lines are hooked up rite. so could the heated oxy sensor be causing this running issue?
