B18 Interchangeable Replacement parts?
Status
Not open for further replies.
Aquariust
Hello All,
Just purchased a B18a out of a 91 teg ls. It is missing the alternator, distributor, fuel rail, and the exhaust manifold.
I was wondering if anyone knows what parts are are interchangable, for instance, can a distributor from a 94 gsr work on this engine?
Or less detailed, for instance, will parts from a b18c work on a b18a. What years are interchangeable, for instance are b18's from 91 the same as in 97?
Are any of the parts interchangable with 88-89 tegs, like the distributor?
Thanks for any help you can offer!
-John
it all depends on which parts u need the gsr distro will not work for the motor u have because it is obd1 and the motor u have is obd0 or pre obd and im not positive but as far as i know most parts that matter performance wise will not work from b18c to what u have...also no 91 to 97 is not the same like said before 91 is obd0 and 97 is actually obd2 and as far as the 88-89 tegs go i dotnt think anythingis interchangable that isworthwile
Please refer to our FAQ. There is no need to post your topic more than once.
This topic has been closed by a moderator. Please continue your question in the other thread that you started.
Thanks, Moderating Team
:locked:
Status
