b18 timing cover
Discussion in 'Engine Building' started by b18b1_delsol, Mar 18, 2009.
  1. b18b1_delsol
    b18b1_delsol New Member
    Ohio
    Will a ls b18 lower timing cover work on a b16?
  2. Matts96HB
    Matts96HB . Moderator VIP
    Can't say for sure, but I'm pretty sure it will work. I've never tried this though, I would assume B-Series covers would have to be the same or else a timing cover for an LS-VTEC would not be possible.
  3. brian11to1
    brian11to1 Senior Member
    lower? i dont think they will as the deck heights are different.
  4. thompy.mark
    thompy.mark New Member
    Yup, it should be a straight fit. Had covers from a b18b and b16a sitting next to each other, and were pretty much identical. As far as I can tell the extra material for the taller deck blocks is in the upper covers
  5. brian11to1
    Ok, I wasnt sure. But I do know if the block/oil pump is from a (96+) and the timing cover is from a 90-95 you will have to trim the lower cover to fit.
  6. esi42
    esi42 Member
    1st gen b16a is the same as 1st gen b18a
    2nd gen b16a is different than 1st gen b18a.
    Ive never owned a b18b so I can say for sure on that one.
  7. DickBswapn
    DickBswapn New Member
    Philly Burbs, PA
    I have had issues with this. It depends on the oil pump. What B16, and what B18 cover?
  8. b18b1_delsol
    Ohio
    00 b16a2 motor and 95 b18b1 lower timing cover.
  9. brian11to1
    Like I said above, you will have to trim the lower timing belt cover in order for it to fit.
  10. b18b1_delsol
    Ohio
