B18a Swap Into 90 Crx Dx
Discussion in 'HYBRID -> EG-EK / DC' started by mwasnp, Feb 27, 2003.
  1. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    I have most of the swap in my garage right now, just need the ecu, distributor and axles. What axles do I need. I keep hearing of complications with this swap because of the axles, do I need custom ones, or if not what axles of of what car will work for me? I hear I need different left and right ones? Any help would be appreciated.
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    here is some good axel information:
    http://www.hasport.com/News/Articles/Haspo...ort%20Axles.htm
    if you decide to go with the 90-93 teg axels, then you have to remove thedust seal from the inside of the hub. but that HASport page has good info on the subject.
  3. mwasnp
    Hopkins, MN
    The article seems to be a good one but I am still confused. If I get 91 integra ls axles would that be all I need? Thanks for the info so far...
