b18a1 crank strong enuf?
im doing a turbo 11 psi setup on my b18a1, and im wondering how high can i rev the stock creankshaft, im gettin je pistons and eagle rods so they are not a cause for concern, but the crank i want to keep stock, because its fucking 800 bucks for a forged one
by the way are there any other mods i should consider while im redoing the whole motor......
thanks
matt
serisouly consider a crank gurdle, such as in the GSR block, it helps prevet crank deflection.
we're running several 600-800 HP LS/VTEC with stock crank. and they hold up just fine. GSR girdle is not necesarry.
