b18a1 into 91 dx trans ?
javenger
trying to put a b18a1 auto trans into a 91 dx auto, will i be able to use the stock trans cable/linkage? does the b18a1 auto trans use a cable or shaft/linkage type. what does the dx use to shift the gears?
what needs to be done for this trans to work in the 91 dx?
come on now guys.... tryin to put a b18a1 with an auto trans into a 91 dx that is auto...
thanks if anyone can help
is that cable for the auto trans, and is that exactly what i need in order for this trans to work in the 91 dx with an auto set up?
its for the auto, as to whether or not you need it, I dunno... I dont run into people who do this very uncommon/:ghey: swap.
is the rear motor mount bracket the same on the MT and the auto trans in the b18a1 that came out of the 91 tegs?
