B18A1 swap into Civic EG4
jaceh_honda
JDM freak
Hi ! This Is my first post on this forum I'd like say Hi to all Ya ....
The problem is :
I have B18A1 Integra 90-91 /with some mods -> about 200 hp ...
I'd like swap this engine in my Civic 92-95 - EG4 , My questions are :
->can I put drive shaft from my integra to civic or do I have to put some frome civic vti ? :ph34r: Which oe will fit best ?!?!?!?!?!
->what about axles ? Which one I need to get ?
->does motor mounts from integra will fit to my eg civic ? or I need to get those from vti /civic B series ?!
best wishes jaceh_honda
if you have a d-series, you'll have to swap for the teg axles. motor mounts should be the same, if you pull a motor, get the mounts too, and you can swap them if you have any problems.
Ok so I need to swap axles from integra 91 then this will fit to civic /eg4/ right ?!
thaks for answer !!!!
