B18B engine into civic EG...what upper rad hose do i need?
mr.rhtuner
its simple, find the hose for your head which would be a "b18b/a" cut the length shorter if need be.
thread/.
use stock b18b hoses and new hose clams as the stock eg radiator is a little smaller you will need to tighten them up. and that works perfect.
thats what i have in my car
94-99 integra ls upper and lower hoses
yeah the rad side will be a smaller tube, you can either do what was said already, or buy a set of hoses from Samco, they make hoda swap hoses for most swaps.
you can either use the rad. hose from the ls or the ones from the civic..
The one from the civic is a little smaller, but still fits.
I have a b18 in my fodo' and i kept the civic stock radiator hoses.
Good Luck!
