Ok heres the story... ive just put a 95b18b manual in a 97 civic HB (automatic) Everything is done and the the car runs very great... the only thing is.. NO CHARGING AT ALL...!! my car is canadian so i had a 3 wire alt. I connected the black/yellow w/ balack/yellow, white/blue w/ white/blue, white/red w/ white/red and the white/green directly to pin A16 on the ecu. (I followed all the diargrams of ALLDATAONLINE.com... so in my mind the wiring is correct.) I also have a speedometer issue.. so I checked the fuse 15: its good.. i check also fuse 41 and 42 evrything is good ( I know the alt is good cause I took it from my old integra where i took my engine.. everything was working fine..) any idea??
ive read a lot of forums with ppl having the same kind of charging+ speedo. issue and every1 seems to have a short on the fuse 15...
other info that may be good to know: the battery light (or in dash charging issue lamp) is not light on.... and my speedo. was working on my 1st road test but the pointer was acting crazy... HELP PLZ I NEED MY CAR NOW ...
